Correct Angles/Ride Heights or Correct Bite?
Helping a buddy with B-mod. Set up sheet states certain upper control arm angles for front suspension and measurements from top of rear housing tube to overslung tube in rear. Problem is that with these settings on the money, the bite is near zero. We’ve had good results with about 50 lbs of bite on dry tracks. Option 1: we can get the 50 by cranking in and out evenly on all 4 corners, but the front angles/geometry is not to spec (too much angle LF and too little RF). Or Option 2: we can crank into the LR spring until we get our bite while maintaining front angles. This, however, leaves the LR ride height about 1 ¼” higher than spec. Which method would be the lesser of two evils? Thanks.
