I know it's early in the season. But, this race could be in the top five for race of the year. Great race!
Transponders are the most accurate way, there is no personal judgement involved. I get it, Thornton was on the losing end last night, but I'm guessing at some point he has been or will be on the other end one day.
.007 of a second. Using the eyeball test, the guy with a longer front bumper will win every time.
DOD has a picture, I wonder if that's the finish?
The problem is the series run at so many different tracks that it is tough for them to have somthing consistent. If their was a line in the wall and a camera dead in line like eldora it be one thing but alot of tracks don't have this so the rules for the series are when in question they go to the transponder and that is official. Doesent realy matter where the loop is located if that is deemed the line by the rules that's it. This is why they have a rule on the placement of the transponder because it will be the decision maker. They checked the transponder positions before they declared a winner. I wanted to see rtj win as much as anybody but he didn't. Bottom line great race great finish
The problem with transponders is theyre mounted on the rearend…..approx. 15 ft from the front of the nose!
A car 1 mph faster can travel 1.46 feet in 1 second!
Exactly zero !!!
Transponders are mounted in the front.
Sure thought Thornton won it. But I have no way of debating the out come. Really like this guy, and maybe he can get them back tonight. Great race
Lot of good points made, especially zero25's and the comments about the transponder receiving cable location. One touring group we run with recently changed transponder locations on the cars from front at lower A arm to midplate and there are flaws with each. A inch or two either way can cost or give you a win.
One of our regular haunts last year saw a guy get his first sprint car main win taken away because their wire was buried coming out of turn 4, where he was second on the last lap, instead of at the start/finish line where it should be and where he definitely won by about half a car.
Transponders are great for most lineups getting sorted out on restarts but the old fashioned human scorers and/or a camera at the finish line are better for determining the winner.
When Nascar was at Darlington a couple weeks ago they showed the finish between Craven and Kurt Busch a couple times. Ricky won because that Pontiac nosepiece was slightly longer. Had he been in a Ford like Busch I believe it would've been a tie
Wow, it sure looks like Thornton won that race, from that view. Transponders are supposed to be located at the rear axle on all cars I believe, I assume they do check the locations of them after the race.
There could be some tricks played with transponders. It has happened before. Not in Lucas that I know of.
transponders are good for determining the part of the car that crosses the line 1st, I dont know where woo mounts theirs at, I assume axle tube, ricky could have crossed the line 1st with the nose of the car and still lost according to transponder.
The transponder isn't even at the very front of the car? Isn't that like the olympics judging the winner of the 100m dash by the back of your head crossing the line?
I've seen local tracks that say the transponder has to be mounted on the rr axle housing.
