2006 MasterSbilt IMCA late model
2006 MasterSbilt Smackdown S7 w/Gen X Rf option
Dry sump – Barnes 5 stage pump – tank w/heater
Winters rear end
Bert Transmission
Aluminum drive shaft
Wehrs aluminum J-Bar
PPM uppers, lowers, S7 spindles, 4 links and Birdcages “Birdcage bearings 6 nights old”
Spare uppers, lowers, and spindles
QA1 ball joints “3 nights old”
BRT 3.9 rack
Scalped / drilled light weight rotors w/ MasterSbilt calipers electric RF shut off
Optima Red top Battery “6 nights old”
Hooker Harness belts w/ ratchet and gel pads “3 nights old”
2 bead locks 2 non w/ 4 IMCA tires “Tires 3 nights old”
Your choice of 6 Afco 13 series shocks and springs w/duel stage setups
All 4 corners plus traction and 5th coil shock By Speedway motors “6 nights old”
OR
5 Genesis G3 double adjustable shocks and springs w/duel stage setups
All 4 corners plus 5th coil and Bilstein ASN traction shock. “3 nights old from Genesis”
Roller chassis WITHOUT shocks $6500
Roller Chassis with AFCO shocks $7000
Roller Chassis with GENESIS shocks $8500
355 Ford IMCA spec engine “12 nights since fresh” $7000
SVO block 9.2 deck
CP Rotating assembly w/gas ported pistons
ISKY roller cam w/ cam roller bearings
Jesel shaft rockers
C-line dry sump pan
Moroso distributer w/Roush cap and wires
Edelbrock Billet fuel pump
Schoenfeld Headers “3 nights old”
Valve cover spring oilers “3 nights old”
COMPLETE CAR INCLUDES PARTS BELOW $15000
Brinn aluminum bell housing
Brinn aluminum flywheel
Double Pass Radiator “3 nights old”
Chuck Nuytten carburetor “3 nights old”
R2C air cleaner and power base assembly “3 nights old”
MANY OTHER PARTS AVAILABLE IF CAR OR ENGINE SELL... wheels, tires, trailer, scales, engine parts exc...
Call or Text 815-541-3544
