!!!!cheap parts new and used!!!!
*NEW* Pro Comp Starter sbc straight across bolt pattern, red powder coat 3 hp comparable to msd starter, comes with bolts, shims hardware. $110
*NEW* Reverse Mount Starter for brinn/bert bell housing, high torque racing starter, vent holes epoxy to seal out from dirt. $200
*New* Pro Comp Distributor MSD replacement, billet housing, small cap, msd plug in, use with 6al or other ignition box $120
*New* Pro Comp Distributor Mallory style cap, msd plug, billet housing, great distributor run in my car. $110
*New* Pro Comp High voltage coil, aluminum housing, $40
*New* Pro Comp 6al box rev limiter, plugs for msd style distributor
Needs to go $100
*New* QA1 5/8 heim joint kit, 4 left hand 4 right hand with adjustment nuts $75 or seperate for $11 each
*New* SBC valve covers with breather tubes, black powder coat, $50
*New* King rod and main bearings standard for 350 sbc $100 for both
*SOLD*MSD distributor small cap, bronze gear, billet 85551 part number, with spark plig wire retainer on cap, *SOLD*
MSD style distributor large hei cap, external coil adapter, aluminum housing, billet gear. $70
Burt/Brinn drive flange
1 aluminum used little wear looks like new, 45
1 steel ran very little 35
1 belt drive steel round tooth 50
Solid lift cam 518/536 nice cam 65
Nascar Style drive flange 5x5 modified style 35 each
2 brrl carb holley 4412 zinc finish, has choke tower but no internals ran 10 times, ready to go $300
Wedge Bed trailer, black, large winch, haul late model without loading tires, $2500
350 stock engine 21000 original miles, make great hot mod motor, or towing vehicle, $750
(606) 259 2710
allenwarnie@yahoo.com
