brashley
ENGINEMaximum 362 cubic inch.OEM or aftermarket blocks. Aftermarket blocks must have standard cam location and OEM cam journal size. Max bore is 4.070".Crank must be minimum 48 lbs. including crank gear. 3.480" stroke crankshaft ONLY with rod journal minimum diameter of 2.100". Cranks may be turned up to .030" for crank repair.Rods must be steel with maximum 6.000" length. I-Beam stock replacement type rods only. No H-Beams or fully machined I-Beam rods allowed.Flat top pistons only with 927" minimum wrist pin diameter. Must have rings in minimum 3 grooves.Small block Chevy aftermarket standard runner steel heads must be 23 degree design heads. No raised runner heads. No aluminum heads. No porting, polishing, shot blasting, or acid etching allowed. No exceptions. Heads must be 23 degrees with 1/2 degree tolerance. May be flat cut. No angle cutting allowed.OEM heads may be ported and angle cut.Steel valves only. Maximum 2.020" intake, 1.600" exhaust. 11/32" minimum stem diameter.1.5 ratio rocker arms only. Stud girdles allowed. No shaft mount rockers.Flat tappet cams only. No ceramic lifters.Stock firing order cams only..842" lifter bore size only.No raised cams , O.E.M. journal size only.No external oil pumps.No aluminum oil pans.Block mount fuel pumps only.No rear mount pumps.Must use Edelbrock #7101 dual plane intake only with no modifications. May use Edelbrock #7116 intake for Vortec heads.One 4150 series carburetor only.No carburetor spacer allowed.HEI style distributors only. Coil must mount on distributor.No MSD boxes allowed.NoTri-Y headers.NO TITANIUM PARTS ANYWHERE!These rules are used in a "sportsman late model" class at a local track here in east Tennessee and the class consistently has more sportsman cars than limited late models even with the pay being 1/3. I feel like it could be the biggest class around here if more tracks would get on board and create a similar set of rules. There are 3 tracks in the area that have a sportsman type class but the rules are structured so differently that a car can not go from one track to another to race. I think that plus extremely low pay keeps several other cars from running in the class. Matt49 I think 604 crates could run in this class without any issue. Certain aspects of this rule set could be modified to allow more people the opportunity to race what they have without too much of a negative affect.
