2005 rocket, WISSOTA rules, D-55 tires.
Springs LF-450, RF=400/600 dual rate, 1.25" gap. LR-200, RR-225. 5th-afco progressive with 0-.25" preload
Shocks - integra, set for dryslick
Rear bars LRT-top, RRT-Middle, LRB 2nd up (using 2" shorter arm and plate), RRB 2nd up.
Panhard bar is 8.75" up on the frame, pinion is bottom of slider, approx 1" below driveshaft.
left side is 54.5, rear 54-56 depending on fuel, usually run around 70-80# bite in the LR, for the race last night put 6 turns in the LR and it was better.
I have the RR shock on the inside mount, also have a 2" drop mount on the top (lowered the spring table).
1st part of the year I struggled getting the car free'd up when there was tack. The last few weeks the track has been very dry and slick. There are some ruts and rough spots through the corners but it's getting better. Overall the car seems to work pretty good, it has decent drive off of the corner, doesn't seem to be too loose or tight going in and through the middle. Just can't seem to get the car onto the RF often or consistently, and it kind of feels like there should be a bit more side bite in the rear of the car also.
I generally drive the car straight, I like being able to roll into the corner and pick up the throttle as soon as I can vs the guys who barrel into the corner sideways.
I think I might need to open the gap on the RF dual rate stop up a bit, let it get a bit more of soft spring lean before it hits the stiffer spring. Keeping a bit more LR bite in the car should cancel out the drive issues of increasing the gap on the RF hopefully.
I've been center or just above the driveshaft with the panhard bar when it's tacky and that does help, just doesn't seem like lowering it does as much. I haven't raised it on the frame yet. I've toyed with the idea of a shorter j-bar (current is 21") or possibly a straight bar, but with the ruts I think that could upset the car too much.
Any other ideas off the top of your heads to look into and try?
