Latemodel Parts - Team Sell Out - (Shocks/Rearends/Headers/Trannys/Misc Parts)
Shocks
AFCO – Control Shocks (1) - $50
AFCO – (2 sets) Silver Series Built By DPL Consulting for Rocket Car - $1450
Bilstein – Set of Steel SN2 Series (4) - $475
Bilstein – Set of Aluminum AS2 Series (4) - $775
Bilstein – Aluminum AS2 Series RF Stack Shock - $200
Rear End
Frankland 4.11 Rear-end (20 Races since fresh from Frankland) – Out of Rocket (has pinion plate and ladder bar mounts) - $900
Rocket TWM Grease-able Bird Cages (1-Set) - $250
Rocket Lift Bar (2-Piece) - $100
Oil Pump / Tanks
Peterson 5 Stage Oil Pump (Fresh Rebuilt) - $850
Pulley and belt for Oil Pump - $75
PRC Oil Tank (w/Dual Returns) - $325
Oil Cooler (Used) - $50
Transmissions
Bert G2 Tranny - $1900 (15 races on since new) (w/shifter&linkage)
Bert G2 shifter w/linkage - $70
Carbs
Stealth - 1.45 Gas Carb (Fresh) - $850
QuickFuel – 950 Gas Carb - $500
Holley – 4150 Gas Carb - $300
Super Sucker 4-Hole 1" Carb Spacer - $35
AllStar 1" Carb Spacer - $30
Rocket Parts
Rocket B/F Spindles (Different Combos) – (2) Sets (New) - $200 set // (4) RF (used/good) - $50 Each
Front End Parts
Howe Ball Joint Replacement Stud – (New) - $20
AFCO Bolt In Upper Ball Joint (Low Friction) - (New) - $25
Mono Ball Studs - $10
Misc. Lower Control Arms - $30 each
Misc. Strut Rods w/ Heims - $20 each
Misc. Radius Rods w/ Heims - $15 each
Misc. Upper Control Arms - $40 each
New TMW 8.25" Upper - $100
Distibutors
DUI Crate Distributor - $300
Crane Digital Distributor w/ New Wire Set - $600
MSD/Ignition Parts
QuickCar 3 Switch Panel w/ switches and wiring - $40
MSD 6AL Box - $120
MSD 7 Gold Box - $190
MSD Soft Touch Rev-Limiter - $100
MSD HEI Chevy Cap - $40
MSD Rotor - $15
Drive Shafts
Steel D/S – 39” - $75
Wiles Carbon Fiber – Crate Drive Shaft - $400
Headers
Beyea – Chevy Angle Port Tri-Y’s - $275
Wheels
Non Bead (7)- $120 each
Non-Bead w/ Tabs (3) - $160 each
Bead Locks (7) - $190 each
Radiators
KEYSER - 19 x 27.5 Double Pass (New) - $175
AllStar - 19 x 28 Double Pass (New) - $125
PRC - 19 x 27.5 Double Pass w/ Water Pressure Bung (AN Top Hose)(Used) - $100
PRC – 19 x 27.5 Double Pass (Used) - $100
Springs
Misc. Coil Over Springs for Dirt Latemodel – Various Length/Rate/Brands - $30 each
Other Parts
Joes Shock Canister Holders (4) - $40 Each or $150 for set
"Original" GM 4-Blade Fans (Used) - $45 Each
GM Water Pump (used) - $35
Steel J-Bar w/ adjuster - $50
PPM Travel Limiter (New) - $75
Vinyl Air Cleaner / Breather Covers - $20
4-way Lug Wrench - $20
Oil Cooler Tuber (2) - $10 each
Under Hood/Hood Scoop Cold Air Box - $75
Bert Balance Fly Wheel w/Belt Drive (2) - $35
Multiple Fan Spacers - $20 each
Used R2C Filters (14x4) - $40 Each
Used R2C Breathers - $10 Each
R2C Top Air Cleaner - $40
Air Cleaner Top/Bottom Kits (3) - $40
Wheel Foams (12) - $5 each
Call or email
618-781-1522
618-973-1064
cschuster@tmcitransportation.com
