NEW 362ci 23* STEEL BLOCK 11X HEAD ENGINE
NEW 362ci 23* STEELBLOCK ENGINE
Phantom Race Engines # PRE367
Dart SHP block w/350 mains,4.155 bore,50mm cam
Callies 3.335 stroke crank,350 mains,2" rods
Liberty 6" billet rods
CP 4.155 dome pistons,.043 - .043 - 3mm rings
Brodix cnc ported 11X aluminum heads
2.125 X 7mm titanium intake valves
1.580 X 5/16 titanium exhaust valves
Hornick JHE 10A valve springs
Jesel 1.60 - 1.60 Pro Series shaft rockers
Morel .937 keyway roller lifters
Comp Cam 50mm 8620 billet roller cam w/LS firing order
⅜ X .135 wall pushrods
Edelbrock 2926 intake
Gibbons billet aluminum valve covers w/oilers
Dan Olson aluminum drysump oipan
MSD billet distributor
Scott spark plug wires
Bosch F09CSO sparkplugs
MSD crank trigger
ATI balancer
Stewart stage 3 aluminum water pump
Jones serpentine pulley set
Stealth 1.405(850cfm) lightweight billet carburetor
13:80 compression
Timing - 36*
Valve lash - .016 hot
654hp @ 7000rpm
542# torque @ 6100rpm
$30,500 w/carburetor
Pictures & dyno sheets are available by email
EMAIL: terry.marciaburnett@gmail.com
PHONE: 865-567-6943
