377ci SBC UMP Modified Racing Engine runs on alcohol
377ci SBC alky UMP Modified Racing Engine Proven Winner.
I took it back in from the guy because he was getting out of racing.
Block = Dart Little-M with 4 bolt
steel splayed caps + front
and rear steel main caps.
It also has Dart Coated cam bearings
and ARP head studs
Bore = 4.155
Crank = 4340 grind balanced SCAT Ultra Lite
Stroke = 3.500
Rods = Manley 6.125 I-Beam w/ARP 2000 bolts
Pistons= Mahel .250 Dome + 11cc 4.155 Forge
Cam = 4-7 Swap custom ground RG14S
Heads = Brodix Ported Modified Aluminum spec heads w/2.08 intake
and 1.6 Manley Race Master valves and Titainum Retainers.
Manley #2211443 Valve Springs
Rockers= T & D 1.6in & 1.5ex very nice
Intake = Holley aluminum port matched Hi-Rise w/water
lines and aluminum swivel water neck and temp sending unit.
It is ready to got with a MSD 8555 distributor and MSD wires.
Aluminum water pump with Aluminum Coleman pulleys
It has a Avon Racing PG-3100YST timing set.
This engine takes a 350 style flywheel and balancer
and has a Pioneer 6 1/4 but no flywheel.With an aluminum
oilpan and valve covers with breathers.
PROCESSING TIME:
In most cases I will ship the same day or the next day after I receive payment. Although, I do sometimes get busy with my day job, working in my raceshop or family things. It may take me 1-2 days to ship the items out after I receive payment. I'm sure you understand.
SHIPPING/FREIGHT COST:
Buyer will pay all shipping/Freight costs. Will have to be crated and shipped out on truck freight. Contact me with your shipping info (zip code) for a shipping quote.
LOCAL PICKUP: If you are in the Moline, IL area and want to pick it up or look at it. I most certainly can do that, just contact me to arrange a time.
$7500.00 O.B.O
Call 309-762-2323 8-5 Ask for Adam
After 5 call Eric @ 309-791-1224
View in link seen here
http://www.racingjunk.com/Circle-Tra...ng-Engine.html
