dirtdobberrr
Many smart people that I have talked setup with seem to miss the fact that if the lr is on the chain, no amount of adding bar angle or extended load to the lr will matter to the car at that point. If you want to add left rear drive/and decel wedge, add it by raising the rf ride height 1/2 of an inch. This adjustment adds lr drive even if the lr is on the chain at the point where you need more lr drive. A very similar adjustment would be to lengthen the lr chain 1/2 inch. This assumes that your lr shock(s) will allow the lr to travel another 1/2 inch. Wedge adjustments and adding or subtracting drive from a rear wheel are both adjustments that work for anything from a bomber car to a Cup Car.
