2014/2015 Mastersbilt By Huey, Trailer, Engine etc.
2014/2015 Mastersbilt by Huey Multiple feature winner in 2014. Steel Block Bandits, Ultimate Super Lates, I95 Challenge Car was bought new in February 2014. Car comes with following items: -motor plate -complete NEW 2015 front suspension -new nosepiece,bumper and t bar -new sheet metal -sweet rack -collapsible steering shaft -quick car gauges -wilwood master cylinders and pedals -3 wheel brake switch -msd box -coil -solenoid -power wire -master switch -shifters and linkages -PRC oil cooler -wilwood starlite 55 hubs -wilwood .810 drilled rotors -barry wright fuel cell -winters thermal coated and REM Polished 4.11 rear end only 4 races old -rear end fill tank -wilwood ultra light drive flanges -TWM birdcages -2 pc. out pace lift bar -6th coil assy with spring -climber pinion plate -j bar -climber j bar frame mount -NEW in the box Keyser double pass radiator -Coleman fully adjustable accel pedal -Keyser shaker screen -Kirkey 16" containment seat -Full Set of Double Adjustable Integra MBH shocks including 5th coil -Bert Ballspline Trans -Bert Reverse mount bellhousing. (Has been repaired but works perfect) -Reverse mount KRC Power steering pump Car does not have calipers, hoses, headers, belts, oil system, tach, battery or driveshaft $16,000.00 2002 Millineum 28ft enclosed race trailer. A/C, 110 lights and recepticals throughout, wooden ramp overs professionally built, 4000lb winch with battery and remote, cabinets and closet, 4 new tires, new brakes. $7500 Brand New ARM 358 all steel engine. Callies 43lb crank, Dyers 6" rods, roller cam and lifters with 4/7 swap, Mahle 14/1 dome pistons, Dart 230 runner heads. Engine is wet sump and fresh off the dyno. Ready to bolt in and race. Complete with Baker 750 carb and aluminum 2" spacer. $9000 Please send message here if interested.
