Leaking bert trans
My bert is leaking towards the front and coming out of the bell housing. I took it out and put a new front seal in and re-sealed everything and put it back in and it still leaking after that. Where could it be coming from? I dont see anything obvious.
It's leaking where the lower shaft goes in the case
There is a o-ring on the lower shaft that goes thru the case and clutch assembly. Look at a picture of a bert disassembled and you will see it.
mine always leaked when removed and reinstalled, dig out the old silicone, clean with 2+2, over fill area with new silicone and install while wet, all better tomorrow .
