I figured this is where I will get the best response. I'm looking to raise my Roll Center and shift it laterally as well. The car does have drop spindles and we have a minimum ride height of 6". I can get Upper Ball Joints with taller studs in a few increments as well. I have also been told different things as to how the lowers should be angled. Should the lower outer ball joint be higher or lower then the inner pivot point if its anything other then level and what happens if its both ways being I have slotted lowers and not sure where to start with ride heights. Please help!
