Need starter help...
For some unknown reason (to me at least), I have broke the mounting holes off of 4 OEM starters so far and I dont have a clue why it keeps happening! Mild built 2.3L with a T5 trans. I use a starter shim (like always), the first 2 starters i only used the 2 holes in the shim & broke the bottom tab. Last 2 starters i used all 3 holes & now break the middle tab. The shims only have the outer holes so I used a washer as a shim on the middle tab. Never had this issue in 7 years of ministock racing. Any help or suggestions greatly appreciated.
If you use the stock plate that goes between the block and bellhousing, there is no need for a starter shim.
I've never owned or used one of those plates. Never had this problem before...rebuilt motor, same bellhousing Ive always used...
You Need The The Flex plate like TM 44 said, it gives support under engine crank.
I got one & installed it shortly after my last post and no more starter issues...too bad the car got totaled 2 weeks ago.
Got another mustang, in the rebuilding process...
