4.5inches from center line of axle tube is pretty common for top or bottom trailing arm, call your chassis mfg or bsb for better guidance. Are you talking about your rr spring angle or lr spring angle?
Around 10-15 degrees is usually close on the angle for both sides unless your wanting more angle on rr. The more angle it has the less spring rate you have, I think. If this is wrong someone please correct me.
4.5 inches from center line of axle tube is common, how much do you have?
