Willy’s equalizer carb
Has anyone had good luck with the willys equalizer carb on a 604 crate with methanol.I know the carb main body is smaller then normal but suppose to flow the same amount of air. Having a problem getting out motored when I have running full throttle 90% of the time around the track.
No experience with the carb but your probably not getting out motored your probably not caring enough corner speed. Just because you never lifted doesn't mean the car was perfect. In general as long as a 604 crate motor runs like it should and doesn't have junk headers and carb bolted on it. They all run good enough to win the biggest of races
