SB Chevy Engine Parts For Sale
**NEW Scat Super Light crankshaft 3.75" stroke w/400 mains, 46 lb catalog weight, never taken out of the box, paid $1250, will take $1000.
**USED Scat Super Light crank 3.5" stroke w/400 mains, 46 lbs, perfect condition, never damaged, $650.
**USED Callies Magnum Plus crank 3.825" stroke w/400 mains & small journal rods, perfect condition, never damaged, $1600 new, will take $800.
**NEW JE dome pistons for 4.030" bore, 3.75" stroke & 6.125" rod. 10 pistons, pins, locs & rail spacers, never taken out of the box. cost $1100. Used set of Oliver Super Lt billet 6.125" rods, like new, cost $1250. New in the box Scat super light F43 44lb crank 3.75" stroke w/350 mains, cost $850. Total cost was $3200+, will take $1975 for all.
**Used set of 6" H-Beam rods, unknown brand, $175.
**Used set of Oliver super light billet 5.850" rods, $800.
**Used set of Carrillo 6" rods w/over sized pin bushings, $550.
**New set of Venolia pistons 4.125" bore, 5.850" rod, 3.750" stroke $375.
**Like new C&S Aeresol Billet Gas carb, $750.
**Like new Jim Evans alky carb, $750.
**Good Gaerte 750 alky Saturday Night special carb, $450.
**Bo Laws belt drive fuel pump with SBC block mount brackets, top pulley & spare belts, $350.
**KSE belt drive tandem power steering & fuel pump, $400.
**KSE hex drive tandem power steering & fuel pump, $400.
**Aluminum water pumps $60-100.
**All Pro 227 CNC ported heads from Keith Dorton. All new titanium valves, Erson polished roller springs, fresh from machine shop/never run. New Jesel shaft rocker 1.7/1.6 ratio & fully ported matching Edelbrock intake w/water lines, $3500.
**Dart 227 CNC heads bare, fresh from machine shop, ready to assemble, $1000.
Call Steve at 314-374-5660 (cell) or 636-677-1320 (days)
