JHobbs26
one way to make the falcon shift easier is to remove the side cover. There will be 2 springs and detent balls, one for reverse and one for low. These springs are held into the housing by the side cover. Grind these springs down with a bench grinder until they just barely stick out past the housing.
This takes almost all the pressure off the detent, which in low and reverse you really dont need that much pressure. My tranny has been like this for 3 years and have had zero issues with it coming out of low/reverse.
