Generally what adjustment/change would you go to if the car spins tires coming out of the turn ?
Need more info . Class , type of car , springs , weight , % ,motor , tires . This will help everybody so they can help you .
Pull some timing out.It will depend on how the car is handling earlier in the corner.If the car was loose at apex I might add a lead on the l/s above the l/r.If it was tight at apex that can cause an loose at exit.
Put some turn's in.
Все утро наблюдал материалы инета, и вдруг к своему удивлению заметил поучительный вебсайт. Смотрите: трикотаж . Для меня вышеуказанный сайт оказал незабываемое впечатление. До встречи!
Change driver.
Generally, increase rear % either with more static weight or get the car to transfer weight to the rear on exit with shocks. We switch out the front tie down shocks with more easy-up shocks to help transfer. Just one method to get there.
