420 - 18* vic hill / chapmann
I have a steel gm block , Aluminum 18* edelbrock heads . CnC"d by Chapmann for Vic Hill . titan valves ? , jesel shaft rockers , It has Eagle Crank , Eagle Rods , New JE pistons , rings , bearings , Comp roller cam and lifters , Double roller chain and gears .Aluminum water pump , pulleys , belts , MSD dist. , bottom end of block was concreted when done to strengthen , all the stamping on heads is visible and was called to verify . the motor has NO oil pan , carb , or fuel pump . sitting here and never fired since rebuid . fresh as you can get $5,500 cash 419-934-5086 . i am running crate latemodel this year and thats the only reason for selling . might even consider partial trade on ??? i just dont need anymore thanks for looking
