Rules dont allow bumps, spring rubbers, bump springs etc, so how can i go about getting the high liad numbers at 3.5” to 4.5” of travel?
Progressive rate springs?
No stacking springs either I take it? Just run conventional and have some fun with the car.
Coil bind.
Maybe a hyperco uht barrel spring?
Make shock mounts that are dampened.
RF, say we mounted the shock on a jack bolt, with no threads, in-between the shock mount itself and the frame mount put a rubber Bisquit. Pull bar bushing etc.
You could make the entire Assy shielded so you cant see the bushing.
Think about a smalll bushing type pull bar, mounted on the RF, and used in the push direction. If i get time i will try to draw something up.
it would not be dampened though would it?
Make a deflective top nut or lower spring cup and coil bind the spring, sure is cheaper then a bump or whatever (grins)
Why not use a stiffer spring and lower the ride height? Generally all we care about is dynamic load anyways. I’ve seen a few Trakstar’s use this strategy with good success.
Because deck height rules
IMCA late model rules? As a former imca promoter at two tracks I really don't have any use for them BUT they have a good set of lm rules that bring this Stoopid world of lm racing under control...
Now back to our regular programming.
