My car is loose on corner entry in the feature but good in heat race ! How should I tighten the car I have 250 175 in the rear should I go up in rate or down on right rear
what wheel offsets you running?
2" on left and 3" on right can fit a 4" on right
What are your weight percentages and your bite?
That's with driver and front springs are 1000 1100
Put 2" offsets up front, 3" on LR and a 4" on RR and take the stagger out of it should help.
Dave
Thanks I'll give it a try!
That's pretty soft of a RR spring if the car is 2800plus pounds. I would put a 225 or 250 in and/or swap front springs.
Stay with 250 unless you lose some forward bite, then go up to 275/300....good luck
could also try dropping left side % some and increasing rear % a little bit. or try flip flopping the front springs.
