what are you using in the rear eye of the leaf when you are running a slider - and where can i find just the bolt assembly for a chevy camaro leaf spring for a slider
Day Motorsports has them. Part #AFC-20235-2
thats for shackles - and i have that - i was thinking of running shackles on the rear but i can still use the sliders that are already there
Put a shackle on the left rear.
is your slider set up for roller berring slides or nyoprine blocks for sides? speedwaymotors.com got the blocks but no other hardware or rollers,... the ones on my BWRC mono leaf car use's the blocks an grade 8 bolt an lock nut...
mine currently has the roller bearing and will continue to use the roller bearing - what do you have in the eye of the leaf itself - the nylon inserts ????
I use the aluminum spring eye bushing. Its either a 1/2" or 9/16" bolt hole through the center. Use a lock nut on the bolt so not to tighten down on the bearings.
