Huge Mini Stock Parts List Complete Sell Out Make Offer
Everything has to go. Sold my car and this is everything else I had. I put prices on some stuff and some stuff I didn't but if you see some you want give me a reasonable offer for it and its yours. All parts are located in Lutts, TN. For more info call or text 256.740.1823
Parts for 2.3L Ford Mustang Mini-Stock
4- Brand New Sticker Tires 2@ 205/60 R14 & 2@ 215/60 R14 $40.00ea.
7- Spare mounted wheels, tires, & tubes all are 14’’ various sizes and offsets $50.00ea.
1- Mustang drive shaft
2- Quickstear Rack & Pinions
2- Black Gabriel Struts
2-Gabriel Red Rider Shocks
2- 2.14 Transmissions with bell housing $150.00ea.
1- 7.5’’ Rear End Hosing with 3.45 gears spiders gears have been welded up complete race ready
1- Lightweight Mustang Front end
1- set of 3.27 gears for 8.8’’ rear end
1- set of 3.73 gears for 7.5’’ mustang rear end
1- 2.3L Ford Thru Firewall Header $25.00ea.
1- 2.3L Ford ACE thru firewall header Brand New (No Rust) $100.00
1- 2.3L Ford Starter $20.00ea.
Numerous Racing Springs $10.00ea.
Numerous 2.3L Ford Carburetor & Fuel Injection Intakes $15.00ea.
2- Racing Electric Fans
1- 19” x 32” Howe Aluminum Radiator
2- New Model Mustang Distributors(No Brain Box) with New Accel Performance Control Modules
3- Sets of Taylor Plug Wires
1- Set of Accell Plug Wires
1- 9”x2” Rechargeable Air Filter with top & base
1- MSD Coil
2- Accell Super Stock Colis
1- Esslinger Adj. Round Tooth Cam Pulley
1= Adj. Square Tooth Cam Pulley
1- Racer Walsh one Piece Belt Tensioner
1- Quick Fuel Holley 4412 500cfm Carburetor
1- Esslinger Aluminum Valve Cover
1- 13lb Steel Flywheel
1- Set of Hypereutectic Flat Top Pistons bored .40 over with 5.2” Rods
1- Windage Tray
1- Ovalport open Chamber Hydraulic Lift Head with Ovalport Intake Has been milled about .125 thousandths No porting or polishing Oversized valves, stock type valve springs, & Rhodes lifters will pull vacuum $200.00
1- D-Port Closed Chamber Hydraulic Lift Head 504 Racer Walsh Cam Has been milled about .125 thousandths has been ported and polished stock type valves, valve springs, & lifters Will pull 150 on compression $250.00
TOOLS
2- 5 gal. Racing Fuel Jugs
1- Racing Fuel Funnel
1- Aluminum tire Stagger Gauge
1- Craftsman Aluminum Racing Jack
1- Vacuum Gauge
1- Compression Tester
1- AFCO Tire Pressure Gauge
1- Holley Jet Kit
1- Actron Digital Timing Light
Safety Equipment
1- Pair Simpson Stealth Driving Shoes Size 13 (Black)
1- Simpson Neck Brace (Black)
1- Pair Driver X Gloves Size L (Black)
1- Simpson Voyager 8 Helmet Size 7 ¾ (White)
Numerous Driving Suits (One & Two Piece)
