Complete LS-7 Engine
I have a great buy on this Engine,it has the following R H S Aluminum Block,all PRO cyl heads The HEADS ARE Completely assembled,T D Shaft rocker assembly,heads and intake are ported,camshaft,roller liifters,crankshaft 4.000 stroke,4.125 bore.
To be totally complete,this unit needs 1 rocker arm shaft,and a cylinder sleeve installed.The block was pressure tested without fault.
I have in the box a new set of Dyer rods 6.125,a new set of Race Tec pistons and ring assembly,new King main and rod bearings.
Yes,it needs to be assembled,but it's only $12,750.00,Please no Mr: MEE-OFF'S
Call me 513-868-8998 or 513-305-9951 and thanks for looking!
I have had many calls wanting to buy this and that,I am not interested in doing that.I want to sell everything at one time.
There are $6000.00 in new parts alone Rods,Pistons Pins Rings Bearings Etc.
