Hey guys,
I’m having problems with my ‘15 Barry wright getting on the bars. Car has a 604 crate motor and weighs about 2360lbs with me in it (54% left, 54.5% rear, 110lbs of bite). The car is really good when there is any kind of traction on the top or bottom, especially out of the corners, but seems like it doesn’t even try to hike up. When it slicks off, I’m always bad loose exiting corners. Any gas at all and the rear end tries to come around on me in a hurry. Still, not hiking up. I think it’s so lose because it is not getting up on the bars.
We’ve scaled it twice checking to make sure the percentages are where we left them. We have a ‘16 Barry wright too that hikes up and hugs the corners. We set them side by side to make sure everything mounted to the rear end is the same. With all of the four links and Jbar mounted the same on both cars we still have the same problem. We’ve tried changing the left rear spring from 225lbs to 200lbs to transfer more weight across the rear and we’ve raised the ibar on the frame probably 2” trying to tighten up. Still haven’t figured it out.
When we jack the frame up in the rear, the rear end hangs freely with no binds and there is plenty of room for it to hike up. Any advice is appreciated.
