$20,000...2017 Lazer Chassis Turnkey 604 Crate Late Model For Sale. 3 nights old.
$20,000. For Sale...2017 Lazer X Chassis #2012...Complete Turnkey Crate Late Model Race car...Spectacular Deal. 2017 Lazer X Chassis #2012 (very last 2017 model) with 1 Inch Out RF Option Chassis had new powder coat 3-races ago All new suspension on all (4) corners AFCO Silver Series double adjustable Canister shocks on all (4) corners AFCO Gas adjustable 5th Coil Shock All shocks custom valved by and set up using the spring smash numbers by Focus Shocks New upper and Lower front control arms New tie rods New Spindles New Wilwood Brake Calipers on all (4) corners New Brake and Clutch Pedals New Master Cylinders Correct Sweet Mfg. Power Steering Rack New Collapsible steering column Fire Suppression System Kirkey full containment seat Simpson 5-point harness All new gauges and dash New MSD Ignition and coil Moroso Ultra 40 Race wires Fresh Air Pump Master Kill switch installed 16 Volt XS Power lightweight battery 16 Volt XS Power battery charger New 4-Link radius rods and heim ends Correct Lazer Billet aluminum birdcages Wehrs Machine Chain limiter Fuel Safe 28 gallon fuel cell Wehrs Machine 1 Inch Wheel Spacer for RR if needed Blueprinted GM 604 Crate Engine, Originally a Hendren engine but last freshened by Ingram Engines Aluminum radiator Aluminum Water Pump Jones Racing lightweight 3-blade fan Jones Racing front belt drive assembly Ingram Billet carburetor Brand new Beyea Stainless Steel headers with extensions, anti-reversion mufflers and dividers New MSD distributor Rear mount tandem belt drive power steering and fuel pump Magnesium Brinn bellhousing Brinn Predator transmission Brand new Fast Shaft Carbon Fiber Crate driveshaft Spare Wiles carbon fiber driveshaft New 4.11 DMI Bulldog 8 Inch lightweight, low drag, thermal coated rear end Gun drilled axles 12 New sets of lightweight quickchange gears Atleast 10-12 sets of other quickchange gears Electric RF brake shut off. Sunoco 110 leftover fuel VP CHP leftover fuel Digital Scales Entire car has only (3) races on it. All spare parts and accessories included.
