Dirt/Asphalt Race Parts (Big Assort.) For Sale
Please don't email. Call nights til midnight at 336-998-8922. Thanks for looking.
Quick Change Grand National Rear 50 laps on rebuild 5x5 hubs, axles, rotors, true track unit $1200 obo
GM 10 spline 3 speed with quick change gear unit alum. installed, uses same gears as quick change rear end. Great for classes where quick changes aren't legal $950
GM 3 speed HD trans alum. bell housing quarter master 7 1/4in 3 disc clutch hyd. slave cyl. $750 all
2 Holley Pro Built and Flowed 2 bbl. carbs 350 flows, 470, 500 flows, 640 w/ flow sheets cost $1000 each. sell $450 each
9" Ford center sections 5.14 28 spl. mini spool $300, 5.29 31 spl. full spool $500, 5.67 28 spl. mini spool $400, 5.67 31 spl. adj. locker $750, 6.50 28 spl. mini spool $450, 6.00 gear $100, 3.50 gear $100
28 spl. carrier w/ pin and mini spool $75
2-31 spl. floater axles for q.c. or 9" one is 29 1/2" gun drilled $50, one is 29 1/4" solid $40
Richardson 16" cup type full containment seat, was $1400 new, excellent condition $750
4 alum seats 15"-18" $75 and up
Butler asa style double wall seat with gray velour cover 15-15 1/2" $200
assort. head supports for seats LH/RH also leg supports $20 and up
New/Used race steering wheels also Paw Saver wheel $25-$50 each
Mattec brand head/neck restraint made similar to a hutchens device, like new $200
Brake psi. gauges/adj. prop. valve $60 for both
New 5pt. seat belts, blk. in box $75
New window nets $20 each
Pyrotect Nomex/Pbi Professional 2 pc. fire suit, 2 layers, red with white stripes size small, ex. cond. cost $450 sell $200
New Halon fire out system $350
New Simpson 2 layer Nomex Head sock dual eye ports blue $50
Simpson Shark helmet 7 5/8" blk. w/ radio ear piece, carry bag and 2 shields cost $750 sell $350
4 l.n. bassett/aero 15x10 wide 5 wheels with 5" backspace, ran one race, paid $400 sell $250
Assort. used 15x10 wide 5 and 5 on 5 wheels chrome and painted, some like new $35 and up
1 l.n. 15x12 5 on 5" steel wheel with 4" backspace $50
2 15x10 steel wheels 5 on 4.5" with 3" backspace $35 each
4 race radios, 4 head sets, 1 charger, 1 push/talk button, 1 radio box $600 all
4 New arp lmsc 99 grand prix/ monte carlo quarter panels, steel 2 lh/2 rh, 2 r/h fenders for same $60 each
1 New 5 star asphalt lmsc monte carlo nose pt # 640/410 blk $100
1 New 5 star dirt grand prix nose, white $100
used late model dirt take off bodies $250 and up
assort. used dirt late model body panels, fenders, doors, hoods, quarter panels $25 and up
used asphalt noses/tails $40 each
2 fiberglass roofs 1-70-81 camero, 1-imca mod. $70 each
New front lmsc sway bar 48 spl. 37 1/2" e+e $40
Wide 5 hubs/rotors $45 and up
Coleman rack npinion with power cyl. A1 condition $375
Assort. upper/lower control arms Afco, etc. $35 each
Assort. Afco Pro Carrera Shocks, c/o and reg. all tested $45 and up
New 19x28 alum. radiator $200
G.Y. g50 spec crate late model dirt tires $50 each
Dynatech sbc l/m dirt stepped headers 1 3/4" to 1 7/8" ex. cond., new heat painted $175
New hyper coil progressive 5tc c/o spring for lift bar 10"x2.5" 175/500lb $50
Assort. pan hard/J bar frame and pinion mounts for q.c. and 9" Ford $10 and up
pr. new sweet clamp on caliper mounts for 3" axle for 3.5" caliper bolt pattern $80/pair
Afco sbc eng. mounts and mid plate mounts, new/used $15 and up
Quick Car biscuit type pull bar for 3 link $25
1 Afco clamp on shock mount for 3" axle tube for 2/3 link bars $30
7 qt. sbc kick out oil pan with doors, tray and baffles, champ style $100
Pair tall sbc valve covers with 2/lh breather tubes $25
1 like new canton ford circle track oil pan kick out style best wet sump made $200
New Ford hp clutch disc 10spl. zoom brand $60
2 Ford 2.3 stock engines for building $150 each
1 Ford 2.3 block $75
