Xtreme Gear - Lightest 9" Ford Ring & Pinions on the Market
How much faster can you go with less rotating weight in your rear end? Can you afford to let your competition beat you with this advantage?
Performance Engineering & Manufacturing, LLC now offers the absolute lightest ring and pinions on the market for the 9 inch Ford rear ends. These ring and pinions can save 3 pounds over a 5.67 conventional ring and pinion.
o Available in 8620 for circle track & high performance
o Less rotating weight means faster acceleration
o Manufactured in the U.S.A. from highest quality alloy steel
o These ring gears require a special offset alloy steel spool
o REM finishing available for less heat and friction
o Quantity Pricing Available for Builders & Dealers
. Ratios available in 8620 gears for circle track and high performance are 4.11, 4.30, 4.57, 4.63, 4.71, 4.86, 5.00, 5.14, 5.29, 5.43, 5.67, 5.83, 6.00, 6.20, 6.33 and 6.50 ratios $280.00 Jobber price.
. Special offset alloy steel spools in 28 & 31 spline for 9 inch Ford $178.00 Jobber price.
Assembled center section CSFSXLW jobber $ 729.00
http://www.pemracing.com/Xtreme-LW-Gears.html
