06 Flexi-Flier Gets Tight when track slicks off
4/4 bar Afco edge shocks, 54% rear, 52% left, 30 lbs of bite, 850 RF, 750 LF, 200 LR spring in rear, 175 RR coil over in front, long biscuit bar w/ no 90/10 shock. Car is perfect when the track is heavy, as the slicks off the car just pushes like a dump truck. Changes we've made are wheel off sets and tire pressures. Reading in other post I am leaning toward moving the J-Bar up on the pinion(right now it is at its lowest hole) the rake is correct for the J-bar. This is the first year racing with the small metric chasis and still learning on how to make the changes to correct the tight issue. Does any one have experience with this issue and what are some of the other changes that can be made? Sorry for the long post and thanks in advance. 1/5 mile banked (Ventura Raceway)
