Willy's Gas Slick Track Carb, NEW Braswell Alky carb & Lots of other Engine Parts
Willy's gas Slick Track carb (SOLD). BRAND NEW Braswell alcohol carb, part number 11741752, for 400+ inch motor, never been run, $950. (7) New Del West 2.02 +100 titaniumvalves, $450. Comp Cams stainless steel rockers, like new, 1.8 & 1.7 ratio's, $150. New 7/16" stud girdle & nuts, $90. SBC Callies CompStar I-Beam rods, 6.125" large journal, $375. Callies Compstar cranks 3.800 stroke/400 main & 3.625 stroke/400 main. both are NOT burnt up but need turned. $200 each or $350 for both. Brand new set of JE domed pistons for +030/4.155" bore, 6" rods, 3 7/8 stroke, with pins, spiro locs, rail spacers, $650. New set of Venolia pistons for 4.125"/std bore, 5.850" rods & 3.750" stroke, no pins, $350. Moroso valve spring tester, part # 62390, $45. Two black Edelbrock 8817 aluminum water pumps,(SOLD) 10 Night old USMTS/USRA 400 inch Brodix Spec headed motor w/the best of parts, $13,000. Brand New set of Brodix aluminum USMTS/USRA spec heads, with or without new Del West titanium intake valves. Lots More! May do some trading? Call Steve at SCP 636-677-1320 days or 314-374-5660 cell or text. Can send pics!
