General Questions on RR Spring Rubbers
For those that have experience:
1) If using two spring rubbers, is there any rule of thumb as to where you place them in the spring (such as centered top to bottom, or with one coil space in between, or close to the ends of the spring)?
2) If using more than one spring rubber, do you clock them up against each other, or space a coil or two in between?
3) Is it unreasonable to use upwards of four spring rubbers on one spring?
Hoping to get a basic understanding before getting more technical with them. As always, any info is appreciated!
