Results 1 to 6 of 6
    Mar 2009
    29
    Default Holley Bowl Screw Thread Size?
    Does anyone know? It doesn't match up in MM or Sae. Have a couple holes stripped out and looking to get a heli coil kit to fit it. Thanks
    Nov 2009
    Glennville, GA
    745
    They make this liquid steel stuff. It's an epoxy that they say you can drill and tap. I wouldn't trust it to hold anything strong, but valve cover bolts, fuel bowl bolts....stuff like that it should be strong enough.
    Crew Chief "Tip of the day":
    They are 12/24, willeys has Helicoil kits for $35.
    Holley also has a kit to repair these. Don't leave home without it!
    Aug 2007
    Festus
    67
    www.blp.com only $24 for the kit with the tap, tool and (10)- 12/24 heli coils.
    Jason Crump
    Crump Racing, LLC.
    Mar 2009
    29
    Thanks guys.. I just didn't have a die to check for #12..
