Results 1 to 2 of 2
    May 2009
    105
    Default 5th Coil And 6th Coil
    Need Some Help With Deciding On What Spring And How Much Preload To Use On... Down Where We Run The Tracks Are Always Slick And Need Max Traction..and If There Is Any Secrets To Setting The Car Up With A 5th Coil And 6th Coil Set Up?? Thanks..black Front End Rocket..
    Question 5th and 6th coil
    if its always slick try a 300 6th coil and a 300 fifth coil at 34inches,the closer to the rearend housing the quicker the reaction is and traction dosent last as long..most rocket guys run a 400 6th and a 350 5th..best of luck..windy..
