SS selling out
Ive got a 79 camaro, car was built around 2004 for big Street Stock shows at Batesville and West Plains. Chassis has been widened. Very Very well built cage. Bought it with the intentions of repainting, and putting a new body on it to run Street Stock with and have decided to go back drag racing.
Car is stripped down to be painted
Moser Floater Rearend with 5on4 1/2 bolt pattern all the way around, big long studs all the way around. 6 light weight wheels 8 or more regular wheels, 14 or so total.
620 gears with full spool, 1 season on them
afco front and rear springs, bilstein shocks,
fuel cell
seat
Brand new mesh style window net with all hardware to mount, never installed
Brand new never installed, fuel, oil, water temp gauges
Brand new never installed switch panel, new 15in steering wheel with splined quick release hub
Lowering blocks, 1 adjustable
Muncie 4 speed Lightened with 1st and 3rd removed
4412 carburetor
Quartermaster mini-clutch
2 or 3 extra flywheels
shifters with extra linkages for muncie and saginaw
several bricks of lead
extra set of front spindles
afco alum radiator with shroud, Phenolic carb spacer, 4 blade fan, pulleys
Body that came with car is black, very runnable, needs left front fender hood and nose piece
Will take $2500 for everthing like it is, or if it doesnt sell soon ill paint it, put a new body on it, put the rearend back under it and sell for $4500
Taking a big hit selling it at 2500 but dont really have the time to mess with it right now
send me a msg or give me a call 501-860-2797 Fred
more stuff
also comes with Quartermaster hyd throwout brg with one night one it, lakewood steel bellhousing, and a new mechanical prc fuel pump.....and whatever else i can find
Does have afco style quick steer also
