Dominator plastic fenders
Anybody using them?If so how are they?
I like them, no problems so far.
zeke23z
they look good, they weigh more than alum, and they break when hit, you cant hammer them back into shape like alum.
I havent seen them in person. But always wondered if the side were left big enough so you could cut them to match the angle of your door? If not then you would have to build the door to fit the finder side.
I broke one putting it on, hated them, love the nose will never do the fenders again.
thanx guys guess i will stick with the metal
Dominator Fenders !!
Hey Poppy -- how could you brake a plastic fender putting it on ?? We have put these things through the ringer--- YES they will brake. they won't wad-up like aluminum fenders do. They will allways be flat -just put the pieces back togeather with some rivits & flat sheet --good to go !! - yes they will brake in half when you run under the car in front of you or hit the water truck --- they will twist a full 180deg. & spring back into place. The plastic sides are good size & fit like a glove !! yes you might have to change the door some !! Thanks Bentley
I was once told by a boss that I could "break anything.... even an iron ball" so maybey poppy and I are related
P.S.... I like the nose. I started the year with one and then had to get a new one. I went with a MD3 cause that what i could get quick. But will be going back to the Dominator nose. Id like to give the finders a try. How are the body lines from the door, finder and nose? Flat, up hill, downhill etc.
where you rivet the outside plastic piece to the fender the fender just split right alon that line. I am willing to bet it was cracked or defective when I got it cuz I had no preasure on the fender when mounted on the car. It never even made it to the track.
Poppy !!
poppy -- give us a call at 419-923-6970 Dominator Race Products --- I will work with you on that there fender ---- like refund / send a new one !! -- let me know -- Bentley ----- Was the part real cold when working on it --- We have had them 30deg. & kick the $%%$ out of them with no problems !!
I will send it back to you, shop is heated so I dont think it was too cold and only one broke. I will send it tomorrow. just replace it cuz i would like to try them and i need a new nose also anyway.
Thanks
Dwane
