Results 1 to 6 of 6
    Jan 2008
    13
    Default imca stockcar frame question
    my question is im building a imca car out of my ump type car ambishouse project i know but im someone mentioned about the rear tail section and this factory seam deal im not sure weather this frame is cut at the seam or closer to the hump but in imca do they check this and enforce it or just let it go and dont worry about it
    Auburn, IL
    2,854
    Your biggest concern should be the fuel pump notching / placement and engine set back.
    Jul 2009
    1,317
    which track will u be racing with it determines how well they check it. if u goto supernationals it will be checked
    Oct 2007
    Winfield, IA
    981
    If your cross member is notched for a fuel pump or altered in anyway......you might as well forget it.
    1,289
    the seam is hard to see if you dont know where it is exactly. here is a pic of my car..the seam is about 2 inches in front of where the tube meets the stock frame.
    frame
    if your frame is notched for a fuel pump just fill it in and set the motor back to imca specs.
    Jan 2008
    13
    thanks stockcar5 i looked and it appers good i guess it all will come down to the tech mans discretion looking at your awsome web sight who builds your cars and are any of yours for sale
