18 degree 377 for sale wet sump steel block $6800
I have a 18 degree 377 w/ dart block, eagle h beam rods, je pistons, the good scat crank, comp lifters, comp pushrods, custom grind cam, scorpian rockers, brodix 18x heads and matching intake. The motor has approx 30 nights since last freshened, so it needs gone through, but I would not be afraid in the least bit to go turn it 8000 rpm's tomorrow. As of right now the motor is sitting in my car and can hear run. this motor dynoed at 692hp when it was built. This is a wet sump and steel block
6800 for motor
7300 for motor and willy's 850 alky carb
Thanks Mark
309-338-4591
