wel, I cant get 4m admen to help. I have sent about 4 or 5 messages to them.
I though i would post this and see if any one could tell me whats wrong.
I get an error when i open this site and when i view others post. here is the error that i get. thanks for any help.
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
4m.net - The Most Opinionated Racing Message Board In The Universe
This was posted on a thread about Security Token. It seems to fix the problem. I don't remember who posted it, but it works.
OK, here it is, unofficial as possible....
IF you are still getting the security token error, here is what to do....
Once you do get in, along the top edge of the forum is where it says
new posts, private messages, etc.... go to 'forum actions' and under
that is 'general settings', click on that button....
Scroll down to the 'date and time options'
Go to where it says 'DST Correction Option'
Set it so it says "DST Corrections always off"
At the bottom, click "Save Changes"
Close the window, come back to 4m and see if it works....
The original point and click interface was a Smith & Wesson
Thanks H3Fan,
That was easy.
I don't know why the admen could help me.
Originally Posted by jr18
Thanks H3Fan,
That was easy.
They did not respond to anyone that I know of....
I was just lucky and came across the 'cure' and it worked....
Glad to have helped fellow 4mers....
Racenut Rambles on Facebook
mind freak (chuck greer)
Racenut, I tried to use you quote to reply but I can't get it to work. So thank you for helping us. I couldn't remember who posted the help.
I have found on the 'reply' and such buttons, it works best to double-click on the button, then if that don't work in a few seconds, click again and it normally will work....
Thanks for the help!!!!!!
Add me to the list of people you helped. Thanks
thanks...worked for me too!!
Worked for me, thanks!!!
#77 Leon "Slick" Sells
Worked for me toooooo, thanks a bunch!
Gill T. Azell
thank you, works great now
