December 3,4,5,2010 Farley Speedway Farley Iowa Race Car Parts Auction!
34th Annual Simmons Promotions Inc/ Farley Speedway Winter Race Car Parts Auction
Mark your racing calendars for December 3,4,5,2010 and make plans now to attend this huge auction event to be held at the Palace Ballroom located on the Farley Speedway complex in Farley, Iowa
Admission will be $8.00 per day with a 3 day pass available for just $20.00
The Palace Ballroom staff will be serving an awesome menu of food and drink throughout the auction!
Doors will open at 5pm on Friday December 3, 2010 with the auction beginning at 6pm sharp!
Saturday December 4, 2010 the doors will open at 8am with the auction starting at 9am sharp.
Sunday December 8, 2010 marks the final day with the doors opening at 9am with the auction starting at 10am.
Cash, Visa and MasterCard will be accepted. Out of state checks need prior approval with SPI. Make arrangements with your bank now as this promises to be a huge auction full of many quality items.
Consignments are still available:
If you have parts you would like to consign we will once again be offering early drop off times to help with your busy schedule.
Parts may be dropped off Monday November 29-Wednesday December 1, 2010. Please call 563-744-3620 to make arrangements with Scott Nesteby to set up a time.
Thursday December 2nd parts may be dropped off any time after 12 noon-8pm. Friday parts may be dropped off from 7am-12 noon. Due to the size of this auction-no parts will be accepted after 12 noon on Friday. No exceptions!
Backes Auction Company of Raymond and Greg Kastli will once again be handling all Auctioneering duties.
Make plans now to attend all 3 days of this awesome event!
Hotels:
Comfort Inn Dyersville Super 8 Dyersville
527 16th Ave SE 925 15 Ave SE
Dyersville, Iowa 52040 Dyersville, Iowa 52040
563-875-7700 563-875-8885
These hotels are only 4 miles from the Farley Speedway!
Many other hotels are available in Dubuque- Just 15 minutes from the Farley Speedway.
Early Consignments Include:
Mr. Gasket Company, Cleveland,Ohio New Merchandise:
#8131 Accel Hei Cap And Rotor Kits- Many Cases Full
#1553+1554 Chrome Fuel Lines -100’s of new in package
#15315 New Lakewood Chrysler Bellhousings-23qty
3 Pallets Of New Misc Gaskets-Huge Load Of Ford Header Gaskets ,Many Intake Gaskets In Huge Quantities!
New Hood Scoops
Cars:
88 Monte Carlo Spi Type Stock Car-New Body, Nice Interior, Complete Roller
Monte Carlo Roller SPI Stock Car
These Items Just In:
4000 Ammco Brake Lathe With Rotor Attachment and Adapters
Drum Only Brake Lathe
Huge Lot Of Dodge Neon Parts
Kansas City Race Team Consignment:
Longacre Scale Set With Cart And Leveling Pads
7 Race Radios With Headsets And Cases
Misc Scanners With Headsets
Jerico 4 Speed
Jerico 3 Speed w/ High Gear Split
Super T-10 4 Speed
Muncie 2 Speed
Muncie 4 Speed
Complete Pit Cart With Lift
Aluminum 2 Row Tire Cart
Quartermaster Bellhousings –Reverse Mount SBC
Race Fuel Dump Cans
2000 Lefthander Pavement bare Chassis
Appleton Power Steering Racks
12 Spline Sway Bars
Many Dry Sump Tanks
Many Boxes Of Calipers-Wilwood and AP
Huge Lot Of Quick Change Gears
Many Coil Over Springs
MSD Boxes,Ditributors ETC
Many Assorted Clutches
Dry Sump Pumps-3,4 Stage
Many Steel Braided Lines And Fittings
New Steering Box
Tru Trak Locker For Quick Change
Tire Rotisserie-Like New!
Many Headers And Exhaust
Coil Spring Rater
These Items Just Called In!
Drill Bits,Mill And Lathe Tooling-All New!
Misc Cabinets-Drawer Type-Some New with Inventory!
Milwaukee Portable Bandsaw with Many New Blades
Huge Lot Of New Sanding And Grinding Discs
Misc Hand Tools-many Brand New
Many Rolls Of New Mig Welding Wire-.025/.030./.035
New Impact Wrenches-1/2.3/4 Drive
New Electric Pumps-Fluid Pumps
Air And Electric Buffers And Sanders
Pallet Racking
Lista Drawer Cabinets
Steel Shelving
All Types Of Air And Electric Industrial Quality Drills
100’s Of Vise Grip type welding Clamps
New And Like New Air Tanks And Air Hose Reels
New Steel Cable
Heavy Duty Chain fall
Electricians Wire Rack
Electric 220v Heater
__________________________________________________ __________Wegner Automotive Used Parts Consignment-Note Note-This is a huge load of merchandise-Wegners have cleaned out all used inventory!-THIS IS A PARTIAL LIST!
4 Sets Of Nice SB-2.2 Heads W/ Manifolds-Excellent Condition!
Many SB-2.2 Heads –Not in sets or some damaged
2 Sets – 23 Degree Heads Complete W/Rockers
Many 23 Degree Heads not in sets or some damaged
2 Sets 18 Degree Heads With Manifolds
3 Sets 23 Degree Dart Heads Ported
Several RHS 23 Degree Head Packages
C3 Ford Heads C3 SC1 Raised Port Heads With Manifold
Bare Chrysler Big And Small Block Aluminum Head Castings
LS1,2,3 Cylinder Heads-Misc Ported
Huge lot of P-7 Dodge Engine Parts
Heads ,Blocks,Mock Up Engine
Many New Hoses And Belts
Oil Lines-All Types
Many Dry Sump pumps And Misc Parts
Huge Load Of Starters-153 Tooth And Reverse Mount
SB2.2 Cylinder Head Stud Kits
Tons Of Piston Rings-All Bore Sizes And Types
Calico Coated-new Rod And Main Bearing Sets Ford And GM
Many Many Many New Fel-Pro Gaskets-many sets!
New GM and Ford V-6 Pistons –Huge Load
Muncie Trans Cases
Many Aluminum Water Pumps
Balancers And Pullies
Clausing Lathe
Many Oil Pans-Wet And Dry sump
Huge Load Of Crankshafts-All Stokes And Journal sizes Ford,Chevrolet,Chrysler
Connecting Rods-All Lengths And Journal sizes
Many New And Uses Pistons
Valve Springs-Huge Lot
All Types Of Roller Lifters
Valve Covers
Cams-All Types
New Quicktime Bellhousings
Sunnen Pin Press With Mandrels And Cabinet
Sunnen Rod Hone With Mandrels
2 Vertical Mills-1 Lagun with 6” Riser,1 Bridgeport
180 Degree Ford And Gm Cranks-All New
Misc blocks- All Types,Bowtie,dart,SB2,18Degree,RO7,A Little Bit Of Everything!
Attention Dodge Viper Builders:
Huge Load Of New And Raced Dodge Viper Engine Parts!
Check Back Daily For More Updates!
Monday Night Parts Consignment Update!
Monday Night 11/29/2010 Updates
These Parts Received in Today!!
Air Jack
New Gray Heavy Truck Jack
Shot Peen Cabinet Complete
9" Ring And Pinions
Rocker Arms
New Msd Ignition Parts
Sun Model #500 Distributor Tester With Mag Pulse Adapter
9" Ford Rear End Jigs Complete-Metric And Std Rears
New HEI Distributors
350-4 Bolt Block-Machined And Ready For Assembly
84 Corvette Wheels
9" Floater Rear End Housings
Rochester hobby Stock Carbs
Holley 4bbl Carbs
Many Bundles Of Braided Hose And lightweight Hose
9" Ford Detroit Lockers
Jesel And T-D Rockers
Brodix Heads And Manifold
Misc SB-2.2 Heads
Tire Cart
Many Sets Of Plug Wires
Drive Plates
Jesel Lifters
New Guides And Ber. Seats
Power Steering Pump And Tanks
Trailer Access.
Ford Brodix Spec Heads
Single Chevy Brodix Spec Head
New LS1 Chevy Heads
New Gauges And Tachs
New Bowtie Chevy Valve Covers
Battery Charger
Many sets Of Titanium Locks And Retainers
Boxes Of Valves
Work Stools
Ford Intake Manifolds
New Ati Dampers
LaJoie Seat-Nice
Many Used Cranks
MSD Timing Computer
Alternator
Electric Fuel Pumps
18 Degree Rockers
Oil Cooler
Many Many Hand Toolsready42005
Private message
