Leaf Spring Chassis to 3 Link
In the process of changing leaf spring over to 3 link. Rear end has everything on it, just not for sure how to put coil overs on it. Right now the frame width is 40", rear end is 60". There isn't enough room to put the coils on the outside of the frame. I would like to run a bracket to put coil overs on rear and shocks on front, the problem is how much spring base is allowable? I have even thought about making bracket to put springs on axle with a bar across the top to put jack bolts in, but it doesn't seem there is enough room for the upper brackets on rear end. Has anyone ever ran a lift bar instead of a pull spring on this setup? The car is set up for this as well. I a wanting to do this so we have a roll center adjustment to get the car to hook. I have thought about coilovers monoleaf, but still in same boat it bracketing. Any input, pics would be greatly appreciated. Thanks
