Results 1 to 5 of 5
Thread: Cam ID
    240
    Default Cam ID
    Can anyone help identify this cam? And possibly have a card or other info for it.
    43035/4147 R106 STD-J T8959 2001-CC
    PA
    844
    Maybe try posting this over on the speedtalk.com forum. Some of those guys are good at decoding them.
    Josh K.
    240
    Thanks, I will do that.
    May 2008
    574
    The first 2 #'s are the lobe profiles. Check the 43035 # again. Cant find it in the masters list.Maybe 4303?
    The 4147 is a NC series lobe on the exhaust. Adv Dur. 296 /264 @.050 .421 lobe lift 106* LC
    Im thinking the Int. should be around 290 adv 257@.050 .429 lobe lift. Comp Cam.
    Hope this helps.
    240
    Thanks for the help. I checked the 43035 again and it is definetly a 5 digit number, possibly a "S" instead of a 5 ?
    Once again thanks for the help.
    DD
