racing77
I have a 07 Rayburn with a zlink rr and a swingarm left rear.springs on the rear are 300on rr and 350 lr.500 on both fronts.Thinking about zlink left also and put 225 on both rears. I also use a pull bar.Will the car be flat or lift ? Is this a good idea?
It should still lift regardless, as long as you maintain the same bar angles. I hope to experiment with Z-link on both sides, but those I've talked too say that SwingArm LR and Z-link RR seems to work better. Hey, dare to be different you may discover something, I don't see why it can't work as well as any other combination. Although 225 springs sound too soft for a Z-link setup. JMO
#77 Leon "Slick" Sells
