Results 1 to 4 of 4
Thread: Oil Restrictors
    Aug 2010
    29
    Default Oil Restrictors
    Oil restrictors on OEM Chevy block. Should I or shouldn't I??
    Jun 2010
    Santa Land
    554
    Need more info on the engine combo you want to run.
    May 2008
    574
    With proper block modifications for oil return, stand-offs or plugs in correct locations in lifter valley and an adequate oil pan ,there is hardly any need for restrictors these days.
    Oil keeps your valve springs cooler making them last longer.
    Glasgow, Kentucky
    4,852
    Quote Originally Posted by hpontap View Post
    100% correct, the only time we had used them was when we had to run blocks and heads that were not allowed to be touched. Untouched block and heads have really really bad flow to the pan and can hold the oil up in the top of the engine. Unless you are required to do the same there is no way I would run oil restrictors.
