Results 1 to 4 of 4
Thread: Rayburn 4-link
    Default Rayburn 4-link
    Can I leave the 14-1 shocks mounted to the rear?
    Or should I take them off?
    Feb 2009
    585
    take it off, you will have a shock on the 5th arm, also that can bind up movement to the rear end
    317
    What happens if you run Rayburn 4 link with the pull bar and brake shock - no 5th coil?
