Results 1 to 3 of 3
    Default 2003 Rocket question
    What should ride heights be? and where should i measure them?
    Thanks
    Jan 2008
    1,910
    call rocket pay $50 and get the book or pm me
    you just got greased
    http://www.goddardwarrior.net
    353
    It depends on the type of birdgages on the rear. The left front is 3 7/8 of an inch the right front is 3 5/8 of an inch. measured between the lower control arm to the main frame rail. The right rear is 5 5/8 of an inch with the original welded birdcages 6 3/8 first version bearing birdcage 6 1/4 in the newest bearing birdcage. there is no offical left rear because is it changes with the amound of wedge you want to run. I have been setting it at one inch higher than the right will be ball park. That is measured between the rear frame rail and the top of the birdcage. It is well worth spending the money to get the rocket set up book. Lots of good information.
