Results 1 to 3 of 3
Thread: Wanted:
    Default Wanted:
    Looking for the following parts and tools/equipment;
    Aluminum Chevy block, prefer a small bore but will consider all depending on price. Will also look at something that has been blown up and needs work.
    Falcon transmission and again will look at something that needs to be freshened if price is right.
    KRC dry sump mounted power steering pump.
    Willey's 750 gas carb.
    Looking for one of those pit lifts you use at the track - used.
    8' or 10' sheet metal brake.
    Apr 2008
    Wisconsin
    59
    i have 2 krc pumps 1 new in the box and 1 used 7 times also the adaptor for 465.00 dollars call 1-920-980-9272
    Ive got a rodeck block 400 mains needs sleeves and some studs. 800.00 you pay shipping or pick up
