Hey guys, I recently bought a mod that has mono-leaf springs attached to the rearend with roller bearing floaters. The coil springs are mounted to the center top of the floaters and the shocks are mounted off the spring pad on the bottom of the leaf springs. It has a long pull bar and a j-bar. The left side of the floater has a locking ring to run it either floated or clamped. Has anyone ever ran this setup and how did it work? I was wondering if I should try this setup or change it up. I'm a novice to modifieds so any info would be greatly appreciated. Thanks.
