383, 358, and a 355 modified motors
1) 383- 4340 3.750 Eagle crank and 6" Eagle 4340 H-Beams, SRP pistons, internally ballanced, 4 bolt GM 010 block, , Brodix Weld Tech aluminum heads. Comp steel roller rockers, stud girdle. the engine has two nights on it since rebuilt, Motor is still in car and can hear run. Complete intake to pan = $3500
2) 358 sbc. Brodix aluminum heads 23* -Roller cam -Roller rockers -Steel crank -Manley rods -Manley pistons -Adams aluminum water pump Complete from intake to pan. Motor was used as a back up 2 times this year. Night 1 = Heat win, Feature win. Night 2 = Heat win, 18th to 5th in feature. Ready to drop in and race = $3000
3)355 sbc. Brownfield 23* aluminum heads -Roller cam -Roller rockers -Steel crank -Eagle H-beam rods -JE pistons Complete intake to pan $2500
located in central IL
309-258-1454
wetsel18@aol.com
