Davis Tech TM-1000SL Traction Control
For sale we have a TM-1000SL Traction control unit for dirt and or asphalt. This unit is Self Learning and is housed inside of an MSD 6AL ignition box. Can cut anywhere from .3 to .5 seconds off lap times, make the car straighter off the corner with next to no wheel slippage. Works by monitoring distributor speed which detects the wheel slippage, from there the traction control unit retards the timing numerous times in split seconds to allow for traction and no wheel slippage. This unit is new and sells for $4000 new from Davis. We're only asking $1,499. Contact Brian at 419-239-4603 or email tdeeps54@gmail.com
